Discussion topic: No broadband
Message posted on 14 Nov 2025 12:25 PM
No broadband
No broadband says internet connection is down but when I go through the my sky process it says there is an issue and then says it's all ok
Message posted on 14 Nov 2025 12:31 PM
Re: No broadband
@HelenK3
The current heavy rainfall may be causing broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
