Discussion topic: WiFi not working
This message was authored by: Hel17
WiFi not working
WiFi keeps going off
Re: WiFi not working
Hi @Hel17  try restarting your router, worked for me.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@Hel17
If the advice from @63johnw doesn't work and you haven’t done it yet use this link to check to see if there are any issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
▪️I AM NOT A SKY EMPLOYEE ▪️
