Discussion topic: No intenet
This message was authored by: JoWalshe
No intenet
Hi there,
My Internet has gone off completely. Could you please contact me to rectify?
I work from home so need the connection repairing ASAP.
Many thanks in advance,
Jo
Re: No intenet
Hi @JoWalshe  mine went off this morning, I restarted the router and it's working again, maybe worth a try.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: No intenet
@JoWalshe
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
