This discussion topic has been answered Discussion topic: WiFi not working
Message posted on 07 Oct 2025 01:52 AM
My WiFi is not working but the service checker is saying everything is fine when it's not?
Message posted on 07 Oct 2025 05:45 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If not, use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
