Discussion topic: WiFi not working
Message posted on 02 Oct 2025 02:59 PM
WiFi not working
WiFi been going on and off for the past week and not working at all
Message posted on 02 Oct 2025 03:08 PM
Re: WiFi not working
@EllieBolton
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
