Discussion topic: WiFi not working
This message was authored by: Lauren4997
WiFi not working
WiFi light was orange and now after resetting power the WiFi light is not coming on and there is no WiFi connection
Re: WiFi not working
@Lauren4997
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
