Discussion topic: Broad band not working.
Message posted on 30 Sep 2025 02:38 PM
Hi my broadband is not working. I have tried everything suggested and still nothing.
status says no internet connection.
Message posted on 30 Sep 2025 02:49 PM
Re: Broad band not working.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
