Discussion topic: WiFi not working
This message was authored by: EmilyS3
WiFi not working
I've restarted my sky broadband. I have done tests and everything says there is no connection issue. I have two orange lights one on the voice bit and one on the internet. I've not moved the box prior to this happening. It just cut out and haven't been able to get it back working.
Re: WiFi not working
@EmilyS3
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
