Discussion topic: WiFi not working
This message was authored by: NL29
WiFi not working
Hi
my WiFi at home went down about 20 minutes ago.
Re: WiFi not working
@NL29
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
