Discussion topic: WiFi not working
This message was authored by: Rachael311
WiFi not working
Our WiFi isn't working. We have turned it on and off and it still isn't working. I have ran online tests and it says everything should be working fine.
Re: WiFi not working
@Rachael311
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
