Discussion topic: WiFi not working
This message was authored by: Grace91
WiFi not working
My WiFi is not working. I have tried restarting the router and all lights have now gone green but still not working. I have used the sky app and is staying something isn't working.
Re: WiFi not working
@Grace91
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
