Discussion topic: No wifi
Message posted on 14 Sep 2025 10:55 AM
No wifi
Message posted on 14 Sep 2025 11:04 AM
Re: No wifi
@Latisha12
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 14 Sep 2025 11:05 AM
Re: No wifi
Thank you! No Internet. Seems to be a wider problem.
