Discussion topic: WiFi not working
Message posted on 30 Aug 2025 07:19 PM
WiFi not working
My WiFi isn't working..
Message posted on 30 Aug 2025 07:22 PM
Re: WiFi not working
@Clio2
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
