Discussion topic: WiFi not working
This message was authored by: Midgley649
WiFi not working
Broadband reporting no issues but no devices that were previously connected will connect to WiFi
Re: WiFi not working
@Midgley649
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
