Discussion topic: WiFi not working
Message posted on 20 Aug 2025 11:38 AM
WiFi not working
Message posted on 20 Aug 2025 11:42 AM
Re: WiFi not working
@Shannon193
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 20 Aug 2025 11:48 AM
Mine is the same, have tried the diagnostic "check my connection" page and it's telling me everything is fine. Tried resetting and switching off etc. Had to call them and escalate. There is obviously an issue elsewhere, other people have been complaining about it.
