Discussion topic: WiFi not working
Message posted on 03 Jul 2025 11:54 AM
WiFi not working
Hi, wifi not working despite all the online checks (carried out using mobile signal because as above WiFi not working) coming back saying it is. How do I resolve please?
Message posted on 03 Jul 2025 12:03 PM
Re: WiFi not working
@EmmaPreston
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
