Discussion topic: Saying wrong password
This message was authored by: NEWKY35
Trying to connect WiFi but keeps saying wrong password and I have switched and unplugged everything but still won't take password
Re: Saying wrong password
@NEWKY35
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
