Discussion topic: WiFi not working
Message posted on 12 Jun 2025 06:39 PM
WiFi not working
Wifi not working. Orange light on voice light
Message posted on 12 Jun 2025 06:49 PM
Re: WiFi not working
@Chloe246
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby. Note: the service checker sends routine tests to the hub and won’t necessarily register any issue until the hub fails to respond.
