Discussion topic: WiFi not working
This message was authored by: Nicoleve
WiFi not working
My router has green lights on them all and an orange light on 'voice' but the WiFi will not connect to my tv or phone,
I have tried to restart & unplug the router but this hasn't helped anything.
Re: WiFi not working
@Nicoleve Run the diagnostic service over a mobile device to let it test your line, and follow anything that it prompts.
Try running the line test here to see if any faults are found:
Avatar for Nicoleve
Hi thank you.
it's still not working this morning.
I don't even have a sky landline.
it's literally just the WiFi I have, everything on the app is coming back as ok so not sure where the problem is or how to fix it!
I can't even find a number to contact sky
@Nicoleve So as far as you can see all the lights on the hub are green about the lights is below, also the link about the number, just do the need more help and you will see the number displayed.
https://www.sky.com/help/home
Avatar for Nicoleve
The only light that's orange is 'voice' everything else is green but nothings working
Thank you for the number
@Nicoleve No problem, the voice light being orange and the hub with no internet will be your cause, hopefully sky see it when you call but be sure to let them know that fact when you call them, open 8am onwards, if you are on a FF fttp connection, sometimes removing the wan connection cable from the back off the hub, waiting a couple of mins then back on would get the hub to re-connect, its worth a try....
Avatar for Nicoleve
Cheers thanks for your help!
I can't find the number anywhere though, it's not coming up when I do the more help
Hi @Nicoleve
I have escalated your post to Sky, look out for a message on the forum
I am NOT a Sky Employee
