Discussion topic: WiFi not working
Message posted on 18 May 2025 08:30 PM
WiFi not working
WiFi is not working and hasn't been since Friday
Message posted on 18 May 2025 08:33 PM
Re: WiFi not working
@Harry243
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
