Discussion topic: WiFi not working
This message was authored by: Samuel20
WiFi not working
WiFi just cut out and had 2 orange lights on router and 1 red for LOS
Re: WiFi not working
@Samuel20
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
@Samuel20 The RED LOS is the killer, hopefully the service checker will give you the idea, but you may have to check a few times, updates are not instant!
