Discussion topic: WiFi not working
Message posted on 16 Apr 2025 12:00 PM
WiFi not working
Message posted on 16 Apr 2025 12:14 PM
Re: WiFi not working
@Gamze12
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
