Discussion topic: Internet not working
Message posted on 16 Apr 2025 12:08 PM
Internet not working for a second day, intermittent. Two green lights showing. Have turned off and may come back for a short time.
Message posted on 16 Apr 2025 12:15 PM
Re: Internet not working
@Ron65
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
@Ron65 if you haven't done so run the service checker in the My Sky app using a mobile connection which will tell you if Sky are aware of an issue affecting your line. If it doesnt call Sky to report the issue so they can getvit fixed.
