Discussion topic: WiFi not working
This message was authored by: Lauraclark
WiFi not working
My WiFi isn't working at all and therefore sky isnt working
Re: WiFi not working
@Lauraclark
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
