Discussion topic: dead spot in daughters room
This message was authored by: kevincooper
hello ive just joined sky wifi ive got the sky wifi max but ive got a dead spot in my daughters room all rest of the house is fine.. many thanks kevin
Re: dead spot in daughters room
@kevincooper dead spots are caused by something blocking the direct signal like a metallic object like a radiator. Adding a second wifi source usually helps. If you have the Sky Max hub Sky will supply an extender pod if your sub includes the WiFi Max add on.
