Discussion topic: WiFi not working
This message was authored by: Rachelknight
WiFi not working
WiFi is not working. Light not showing on hub, have tried resetting. Checker is showing no issues
This message was authored by: Jacks12
Re: WiFi not working
Same as mine connects but with no internet
@Rachelknight @Jacks12
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
