Discussion topic: WiFi not working
Message posted on 28 Dec 2024 03:43 AM
WiFi not working
Run tests says it all ok but WiFi not working, it happens all the time. Restart of hub brings it to life, then after a short period it goes again, all devices have same problem.
Message posted on 28 Dec 2024 05:42 AM
Re: WiFi not working
At 3.43 in the morning it could be overnight maintannace that is taking place so if you nit connection throughout the day then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 31 Dec 2024 10:46 AM
Still happening 10.45am and no WiFi, but lights on the hub are green and status says it fine.
