Discussion topic: WiFi not working
This message was authored by: Chloewri12
Message posted on 24 Sep 2024 08:11 AM
WiFi not working
My sky hub says it's connected to broadband but it's not showing up on any devices so cannot connect to the hub, tried turning on and off but hasn't helped
Find out more
Message posted on 24 Sep 2024 08:25 AM
Re: WiFi not working
@Chloewri12 common issue this morning unfortunately the fix for tgecwhite gub is to do a factory reset. Press and hold in the wps button on the right edge of the hub for up to 30nseconds releasing it when the led on the front starts flasshing rapidly green. Oncecrestarted the hub should be back to normal.
