Discussion topic: WiFi not working upstairs
Message posted on 18 Apr 2025 09:35 PM
Hi, the WiFi upstairs keep dropping out and my daughters tv can't even find the WiFi.
I run a test on the app and it says it's fine, but that it is not connected to any devices?? Can you help? it's very frustrating.
Message posted on 19 Apr 2025 06:57 AM
Re: WiFi not working upstairs
@RoseEm Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
