Discussion topic: WiFi not working like usual
Message posted on 12 Jun 2026 06:23 PM
Home WiFi is patchy particularly bad on mobiles
Message posted on 12 Jun 2026 06:39 PM
Re: WiFi not working like usual
@Char2251 wrote:Home WiFi is patchy particularly bad on mobiles
First try unplugging the router for at least a couple of minutes.
If no success have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
