Discussion topic: WiFi not working in Ireland
This message was authored by: Nasher1
Hi my WiFi is not working since the storm here in Ireland yesterday the LOS is flashing red
Re: WiFi not working in Ireland
@Nasher1 That will be the cause, there is NO light on the fibre cable so no Internet!
Avatar for Nasher1
So what do I do now to get it fixed
@Nasher1
Probably disruption to the external optical fibre.  You'll need to log the issue with Sky for attention by the network maintainer from Monday onwards: presumably there's going to be a fairly substantial demand for such support with consently increased waiting times.
@Nasher1 Follow as @TimmyBGood has recommended, if you are with one off the main suppliers they may already be aware and on the case working already, a lot has to do with how the Fibre is getting to you, overhead or underground, OH could be poles down and fibre cable snapped, your local info may give you a better idea!
