Discussion topic: WiFi not good
This message was authored by: Rana721
WiFi not good
Hi I have lawyers lack oof internet and slow
can you help me please
Re: WiFi not good
@Rana721
Your post is difficult to understand… lawyers?
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
