Discussion topic: WiFi not connecting
This message was authored by: Davyjay
Message posted on 23 Oct 2024 10:00 AM
WiFi not connecting
Our phones are not connecting to the WiFi. It keeps saying incorrect password, doesn't accept the password.
Find out more
Message posted on 23 Oct 2024 10:30 AM
Re: WiFi not connecting
Are you using the password that should be printed on your broadband hub because unless you have changed it then it should be this one you need to use.
