Discussion topic: WiFi not connected
This message was authored by: LeahF
WiFi not connected
The wifi router is not lighting up and is not connected to any devices. I have checked the wires and switched on and off and still not working. This is a massive inconvenience as I need my laptop wifi for work. Please advise
Re: WiFi not connected
@LeahF
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
