Discussion topic: WiFi keeps going orange
Message posted on 24 Nov 2025 12:56 PM
My WiFi keeps going down turns orange and then green imma smash the **bleep** up in a min kind regards angry mr Riddings have a lovely day
Message posted on 24 Nov 2025 12:59 PM
Re: WiFi keeps going orange
@Kelvin19
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
