Discussion topic: WiFi keeps going off
Message posted on 29 Jun 2026 09:49 PM
My WiFi routers keeps losing connection and voice. Keeps on having orange lights come on on the voice and internet. Off and on all day
Message posted on 29 Jun 2026 10:19 PM
Re: WiFi keeps going off
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Message posted on 30 Jun 2026 06:50 AM
I know everything else is fine. It's my router that is knackered but it seems so difficult to get a new one going through the app. I work from home in the day and it just keeps dropping out
Message posted on 30 Jun 2026 07:59 AM
@JH3007 in practice line issues are far nmore common than issues with your Sky hub especially if you have a partial fibre line. Sky are likely to swap your hub with the same model if there are indications of an issue. You will have to ring in to request a swap.
