Discussion topic: WiFi keeps going off
This message was authored by: Stevo1983
My WiFi goes off everyday for no reason at all im not willing to pay for something that doesn't work properly
Avatar for Stevo1983
Re: WiFi keeps going off
It's a joke everyday
@Stevo1983 Is it the WiFi or the Broadband they are completely different. The link below may help you work it out!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Iys the hub
It's the hub goes orange everyday at 11am its not on fir what I pay
@Stevo1983 You are correct what hub do you have, it should stay connected, and do you say 11am every day without fails it goes that condition?
Not sure and yes without fail
@Stevo1983 The link above post3 shows all the hubs, look and say which one you have!
Sky broadband hub
@Stevo1983 Can you follow the link and capture, post up like the sample in the post for th table as you see it, and also allow the fields to fill in before doing so!
How to read your Sky Hub statistics
When your hub goes off at 11am when does the Orange light go back to Green time wise if you know!
It's the second and 4th light and lasts about an hour
@Stevo1983 Understand that is going on, the stat's may show something as requested from above, after looking at those then next is the log file captured before during and after for the timeline, nothing in that hub has time switched control to go off/on like that so you are loosing the Internet and voice connections for the period.
