Discussion topic: WiFi keeps going down
This message was authored by: Robert0490
Over the last couple of hours my internet and WiFi connections have repeatedly been dropping out. I'm currently trying to work from home so the internet access is vital
Re: WiFi keeps going down
@Robert0490
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
