Discussion topic: WiFi keeps dropping
This message was authored by: Michelle2214
WiFi keeps dropping
For the last weeks WiFi connection has dropped out multiple times a day. I work from home and it's essential I have a strong broadband connection. Can you explain what the problem is?
This message was authored by: Chris740
Re: WiFi keeps dropping
I'm having the same issues. Don't know what the solution is
@Michelle2214 @Chris740 There is know way for the Forum to say that, it's not Customer Service you may wish to try the link below!
Try running the line test here to see if any faults are found:
