Discussion topic: WiFi keeps dropping
Message posted on 23 Nov 2025 08:05 PM
WiFi keeps dropping
My WiFi keeps dropping. I've rebooted my hub several times and twice today alone. Testing tells me there ids nothing wrong with the signal so is there an issue with my hub / router and how will you fix this
Message posted on 23 Nov 2025 08:20 PM
Re: WiFi keeps dropping
We can't fix it. We are customers on here and this is a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 23 Nov 2025 08:27 PM
@FiFi+Bear Could help if you say what you observe before you have to do the reset etc!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
