Discussion topic: 100mbps broadband speeds
Message posted on 23 Nov 2025 07:44 PM
Message posted on 23 Nov 2025 08:14 PM - last edited: 23 Nov 2025 08:29 PM
Re: 100mbps broadband speeds
@AnnoyedKaren Have a look on the service checker see what is applied on the account side to start with, 80 across the board if you see that straight onto sky tomorrow now 8am to 8pm! Link below Broadband and the > to expand you should see it say Sky Full Fibre 500 as the product! Bad cable between the Port4 wan to the ONT will also pull the sync speed down to the 100Mb/s range takes 1 bad connection on the 8 pins to do so...
See the link below, gives you the picture idea to look for...
Re: Service Checker Issues - Internet Working | Sky Community
