Discussion topic: WiFi keeps dropping
Message posted on 11 May 2025 06:22 PM
WiFi keeps dropping
My WiFi keeps dropping. It is now becoming so u reliable and untenable. I am using so much mobile data tethering and using it in general to watch tv! I work from home
so this is far from ideal. This needs to be fixed ASAP as I keeps happening. I will also be seeking some form of compensation as I raised this a short while ago and it has gotten progressively worse since/
Message posted on 11 May 2025 06:34 PM
Re: WiFi keeps dropping
Auto compensation only applies for a total loss of broadband and/or landline phone.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From the Ofcom website:~
So if your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
As Sky broadband discussed here is a domestic set up there is no extra or quicker support for those working from home.
