Discussion topic: WiFi keeps dropping out
This message was authored by: Andrea130
Hi, my WiFi keeps dropping out. This has been happening since yesterday afternoon
Re: WiFi keeps dropping out
@Andrea130
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
