Discussion topic: No broadband
Message posted on 22 Sep 2025 10:54 AM
No broadband
My broadband is not working
Message posted on 22 Sep 2025 10:58 AM
Re: No broadband
@NickHird
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
