Discussion topic: WiFi keeps dropping out
This message was authored by: Leebee2
My WiFi keeps dropping out from multiple devices (smartphone, laptop, security camera, etc) and this is happening many times a day.
Sometimes when  the wifi drops, it's not even discoverable but after a while it appears again.
I really need some help to get this resolved ASAP as it's not reliable to be able to WFH properly so appreciate your assistance.
Re: WiFi keeps dropping out
@Leebee2
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Leebee2
Thanks for your reply.
I should have mentioned that I tried the standard checks via the app and also a text message with help information and everything looks good from the diagnostic tools so it'll need further investigation.
@Leebee2 Then that will need you to call Sky CS and arrange if they find anything when they run the diagnostics there end.
