Discussion topic: WiFi keeps dropping out
Message posted on 20 Feb 2025 08:53 AM
Message posted on 20 Feb 2025 09:36 AM
Re: WiFi keeps dropping out
@Kimberly333 wifi coverage depends in the layoutvand type of construction of your home. Many houses need more than a single wifi source to get usablecwifi in every room. Check your hub is in the best position which is out in the open on a surface above obstructions like radiators beyond that consider either buying Sky's WiFi Max add-on see https://www.sky.com/help/articles/sky-wifi-max or buying your own wifi kit.
Message posted on 20 Feb 2025 10:12 AM
I've already done all of this and had an engineer out to place everything correctly.
Message posted on 20 Feb 2025 10:15 AM
Mine is dropping out too. This hasn't happened before
Message posted on 22 Feb 2025 06:52 AM
I've already done all of this and had an engineer out to arrange all of the extenders.
Message posted on 22 Feb 2025 08:00 AM
@Kimberly333 suggest you call Sky andcask for another visit but there are properties thst are almost impossible to network using `WiFi no idea if your's is one.
Message posted on 22 Feb 2025 09:28 AM
Thanks. I didn't have any issues with BT WiFi, so think it's just a sky issue.
