Discussion topic: WiFi keeps dropping out
Message posted on 02 Jan 2025 10:55 PM
Message posted on 03 Jan 2025 07:54 AM
Re: WiFi keeps dropping out
@Rahila232 you nedd to esatblish if itscthe broadband connection tomthe hub or thecwifi from the hub tomyour devicecthst is the issue which the lights on your Sky hub will show see https://www.sky.com/help/articles/hub-lights-explained-start
That trouble shooter should show you what steps to take, However the storm the other night has caused loads of issues especially with services over copper lines so it maybe sometimecafter you report the issue to Sky beforecanything can be done.
Message posted on 10 Jan 2025 01:29 AM
Broadband down again - seems to be the weather
Message posted on 10 Jan 2025 08:08 AM
Re: Broadband down again - seems to be the weather
@Rahila232 thst is a question only you can answer but if you are paying £70 a month just for broadband then you are being ripped off most people get TV services etc thrown in for that amount.
