Discussion topic: WiFi keeps dropping out upstairs
This message was authored by: Kayley2004
When upstairs I only get 39mb and it keeps dropping out I can't move my hub which is fibre in a cupboard downstairs I can't use YouTube in my bedroom tv as it keeps stuttering while watching
Re: WiFi keeps dropping out upstairs
@Kayley2004
The hub really needs to be out in the open and not inside anything so a poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
