Discussion topic: WiFi keeps dropping out for over a week
This message was authored by: Carina-Steve+2020
WiFi keeps dropping out several times a day for over a week now.
Re: WiFi keeps dropping out for over a week
@Carina-Steve+2020
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
