Discussion topic: Sky Q Wi-Fi Disabled?
Message posted on 14 Aug 2025 11:44 AM
I currently have a Sky Q 2TB box connected to my Sky router (SR203) via Ethernet. I also have three Sky Minis and a Sky Booster connected over Wi-Fi. If I turn off the 2.4GHz and 5GHz Wi-Fi from the engineer settings on the main box, will this affect the Sky Q mesh and stop the Minis from connecting?
Message posted on 14 Aug 2025 12:49 PM
Re: Sky Q Wi-Fi Disabled?
@lauren1421 if you disable the main Q boxes wifi you will lose the WiFi hot spot it creates and may upset the wifi connection to your Q minis.
Message posted on 14 Aug 2025 01:29 PM
@Chrisee Thank you
Apolgises for the dumb follow up question - buit leaving the wi-fi channels enabled, as well as having an ethernet connected won't double the connection on the router and duplicate traffic will it?
Message posted on 14 Aug 2025 02:26 PM
@lauren1421 @No the Q mesh should sort that for you
